ST6 piping
PLM World Member Genius PLM World Member Genius
Hi Everyone
For those out there doing piping from small machine to large plant design and having ST6 install, check the installation folder for
«Piping Route»
You will find
  • A word document
  • A piping utility
  • Piping sample
Same apply for Frame design (except for the word document), look under «Frame».
Educating a frame section is less important than piping component but can help standerdize you profile behaviour.
Just a suggestion, plan tp place you frame section under template, this will giv eyou teh choice of using them in teh frame or as individual components.
After doing so please remember to go in Solid Edge options and change the file location to point the new location for frame.
