ST7: 3D Sketching in Solid Edge
I am trying to extrude a sketch but I am unable to select the center of it. I think its because its not closed. Any suggestions?
3 REPLIES 3
Re: ST7: 3D Sketching in Solid Edge
It's really hard to guess what isn't going well without any context. Can you post a picture?
laurenj.
Wait you're using "ST7"....are you sure???  >>I'm Jealous<<
All the same,....I'd assume you'll need to make an appropriate selection from the "Keypoint" filter dropdown...in order to find the elemtents desired.
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
Thanks, I will look into that.
