ST7 - File Cannot be saved message
Getting the dreaded "File Cannot Be Saved" error message popping up againm a couple of times a day. Any ideas/preventions?
PC user no network.
G
5 REPLIES 5
Re: ST7 - File Cannot be saved message
I've received that message several times over the past few weeks as well.  I'm on a network, however.  I'm also running ST7.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
We do see this and the only solution I have found would be in the case of an assembly.
If you can't save an assembly all of a sudded you can click the Application Button>New>Assembly of Active Model.
Then click on the sub assembly and click Home tab>Modify group>Disperse command.
Then you can usually save the assembly as a new name.
LMGi
www.TLMGi.com
Ughhh....I'd prefer a BSD over that message.
>touch wood< I haven't seen any sign of this "cannot be saved" message so far in ST8, on both Win7 & Win8.1 seats.
Please read this thread about the File Cannot be saved message:
http://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Solid-Edge-assembly-cannot-be-saved/...
I was so happy to see there is a work around for this.  Until this popped up:
Anyone able to help with this?
McEngineer
ST7
Trained extensively in SW and Inventor since 2003. Dropped into the deep end with Edge...please help.
Version 107.0011.04 x64
HPZ420
nVIDIA K4000
16GB RAM
Intel Xeon E5-1620 v2 (3.70 GHz)
