ST7-Spell Checker
How do I activate the add in for Draft Spell Checker in Draft?
I can´t do it in the same way as I did before, can´t find "Compile.bat".
Best regards,
Geir
ST9
Surface Pro 4
Re: ST7-Spell Checker
Esteemed Contributor
Not sure what "Add-in" you are referring to as an Add-in did not ship with any version of SE to do Spell checking.  There has always been a Macro in the Custom folder, but you must add it to the UI somewhere using the Macro UI item and it only runs "on demand".
Production: ST9 MP10
Testing: ST10 MP3
In ST2, I did this way, see picture.
ST9
Surface Pro 4
I stand corrected!  So this must have been converted to a Macro when the utility was rewritten in a new VB version and to support Office 2010 and .NET 4.
Testing: ST10 MP3
Thank you
ST9
Surface Pro 4
