ST7
I am having troubles figuring out how to combine two different parts on solid edge. They were made seperately and now I need to merge them to move forward with project. If anyone could help it would be greatly appreciated.
Re: ST7
open an assembly template and then add your parts and create relationships between them
you should probably check out the tutorials in Solid Edge Help if you are having such issues...
i understand you are a student but this sort of this is very elementary and if you don't take the time to go thru the tutorials you will frustrate yourself and not enjoy this.
https://docs.plm.automation.siemens.com/tdoc/se/107/help/#goto:xid618399:xid482667
