ST8 Freezing every 2-3 minutes
Hello Community,
Is anyone here getting the same freeze with ST8?
I don´t know why but the ST8 is freezing every 2-3 minutes. I have Nvidia Quadro M2000M Xeon 1505M 3.2 GHz quad core, 16 GB RAM and an M.2 SSD. I have checked in nvidia control panel and everything is in default, as I was using it for over 7 months. And in the solid edge setting, the settings remain the same. It started like 3 days ago, can anyone explain why this might be happening?
(view in My Videos)
Re: ST8 Freezing every 2-3 minutes
Never mind. I figured out the proble. It was really simple. The Image I used to make the sketch was 11 MegaBytes.
