ST8 - Gap between balloon and leader line
There is approx. 1/4" gap between balloon and leader line, for all shapes. Is there a setting to remove gap?
8 REPLIES 8
Re: ST8 - Gap between balloon and leader line
The only thing I can think of is if the balloon leader has a break line and there is a suffix with just a space. So check out the prefix and suffix boxes or turn off the break line.
Other than that, no idea.
Bruce Shand
Honored Contributor
Honored Contributor
Are you using a line style that adds the gap? Make sure the line style is continous.
@12GAGE, That strikes me as very hard, if not impossible, to do. I'd be interested in seeing it done though.
Bruce Shand
Honored Contributor
Honored Contributor
Your right. Once looked at it the control is not there.
I have run into issues with a cap when editing the text enclosure shape (slot, circle, box, etc.....)
I use circles so I don't run into any issues.
Still having the same issue (was resolved, but came back on another drawing). I've checked changed lines, click on and off boxes in properties, but nothing changes.
Again, the only thing that seems likely to me is that there are space characters in the prefix or suffix fields.
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Bruce Shand
That was it! Thanks Bruce!
Good! Mark it as a solution to close this one out.
Bruce Shand
