ST8: Pattern By Table Template
Thought it would be usefull to have an Excel template that will pull the locations from SE.
The attached Excel has some VBA code that will enumerate all the points on a sketch and populate the cells with the locations.
Just create some points on a part sketch and click the button on the Solid Edge tab in the Excel.
The order you create the points is the order they will be listed.
The paint is still wet so test it carefully.
LMGi
www.TLMGi.com
Re: ST8: Pattern By Table Template
Posted it here for those who might need some extra little help.
Hope I demonstrated the template correctly.
~Tushar
