Re: ST8 - Re-attach DIM via ALT key
Me too I can't believe it's related to zoom but so far, that's the only clue I have.
As kjoiner mentionned, sometimes it work, and sometimes not.
Opening different draft files give different behavior.
Will try to create a test case with an appropriate "step to reproduce".
Michel
Ok, I will see what your reproduced steps are.
If you have a report number, please give me the number so I can put our company name behind it.
Daniël Schuiling
may be it has something to do with graphic card and graphic card driver
Try to change them a little and see what happens.
Wolfgang
Wolfgang
will try
Daniël Schuiling
Still no solution...
Daniël Schuiling
