ST8 crash after cancel print
I seem to have an issue that crashes ST8 every time..
Before I raise it, could anybody confirm that they have the same problem.
1 Open a part file
2 Press Ctrl+P to print the 3d
3 Click the cancel button
4 Close the model.
At this point ST8 crashes was a crash log.
Regards Kevin
Re: ST8 crash after cancel print
I followed your workflow, but no problems here.
Edit:
Open
Ctrl+P
Print
Ctrl+P
cancel
close
==>crash (with crashlog)
Solid Edge 2019 & AutoCAD 2019 user
Hi there,
I find the same as @Joris....no crash from that process.
Testing: Solid Edge 2019
