ST8, turn off coordinates when adding parts to assembly?
I can't seem to find the setting to turn off coordinates showing up when I add part files to my assemblies. Only happens on part files, not with sheet metal files. I've gone blank how to fix it...........
Re: ST8, turn off coordinates when adding parts to assembly?
@Trikefreak,
Right-click in a blank area in the Parts Library. On the context menu that appears, there is an entry 'Show Component Coordinate Systems'. Uncheck that entry and the coordinate systems will be hidden when placing a part.
Greg
