ST9 2D drafting
I use solid edge at work and when at home use the free 2D draft to capture ideas over the weekend.
When does Solid Edge plan to lanch ST9 2D drafting?
Thank you
Re: ST9 2D drafting
Esteemed Contributor
Can't say for sure, but it typically doesn't come out untill after the full version has been released in all of its different languages, which takes several weeks.  I would guess sometime in September/October.
Maybe Ricky would be able to provide a better estimate.
Production: ST10 MP5
Testing: SE 2019
Re: ST9 2D drafting
If you have Solid Edge ST9, you have Solid Edge 2D Drafting ST9. You can install Solid Edge and drop in a Solid Edge 2D Drafting license. Let me know when you need it and I can provide a direct link to the Solid Edge 2D Drafting ST9 license for you to download. It takes us a while to get the web pages updated to reference the new software links.
Rick B.
Re: ST9 2D drafting
Hi @rlblack,
I'd like to get this license please......would be good to upgrade the rest of our shop 2D installs to ST9 also, seeing as I have created numerous new files in it already, that they won't be able to open otherwise.
Thanks in advance.
Solid Edge ST10 [MP6] Classic [x2 seats]
Re: ST9 2D drafting
@SeanCresswell are you all using the maintenanced version of SE 2D?
Testing: SE 2019
Re: ST9 2D drafting
Hi @KennyG......no, just Free2D for those.
Re: ST9 2D drafting
Using the free one also.
