ST9 Assembly component Occurrence Properties
Is this working for people on ST9? I'm getting a completely unpopulated table
21 REPLIES 21
Re: ST9 Assembly component Occurrence Properties
Seems to be working for me.
Looks sparse at first. Right click the column header to show other columns.
Modify the CustomOccurrenceProperty.xml to add your own. Then click the Copy button in the table.
Post a screen shot if you think its broken.
LMGi
www.TLMGi.com
Working for me.  Are you using it with the default CustomOccurrenceProperties.xml file or did you customize it?  Can you post a pic of what you are seeing?
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Thanks for the replies.  I believe I've found the issue this morning.  On ST8 I was able to right click an assembly part in the pathfinder and edit its occurence properties directly.  Doing so now just shows an empty list.  However if I right click on the assembly in the pathfinder and select occurence properties it shows a populated list.  A bit of pain to sort through and find the part I'm trying to edit.  A lot of ST9 seems to have added unnecessary steps to simple tasks.
I cannot concur.
LMGi
www.TLMGi.com
So this CustomOccurrenceProperty.xml file is a new thing in ST9. Does it have an entry in the File Locations in the Solid Edge Options dialog and perhaps in SEAdmin?
Bruce Shand
Yes.
@fabricationdesigns I am not seeing this for a single component.  My Occurence Property form has all columns populated for the individual component I ran it on.
I'm certainly not getting that.  Video below
https://www.youtube.com/watch?v=geV7ckpgo3A
