ST9, Can't select reference planes in Assemble
Hi all,
I just upgraded to ST9 and am having a baffling issue.  I commonly assemble parts using the reference planes but it no longer works.  I'm using up-to-date Windows 10 on a BOXX machine with Quadro M2000, newest drivers.
Here's a video.  You can show the reference planes, but can't select them.  It doesn't matter how they're shown, whether using the auto show option or otherwise.
Ryan
https://www.youtube.com/watch?v=UE1WKGAwkZ8
Lab Machinist Solutions, LLC
Waltham, MA, USA
http://www.labmachinist.com
Re: ST9, Can't select reference planes in Assemble
Hi there @rspoering,
I suspect it is because of the "Perspective" view setting......seems more dismisive of selection focus, in ST9. I have turned it off in all of our 3D envirenment templates.
Wow, that was it.  It would have taken me ages to figure that out!
Many thanks.
Waltham, MA, USA
Very welcome.
Just saved me and another user a lot of trouble too ... thanks!  Had a user with the same problem, sounded familiar, looked it up, found this answer and voila!
Why on earth you can select a 'from' planar face of a solid for Mate but not a reference plane as the 'to' face when Perspective is set is beyond comprehension ...
Kevin P. Alexander
I wonder the same.
I just tried it in ST10 and it appears to be fixed there. Also, it is not specific to Assemble/Mate/etc. - reference planes could not be located at all with perspective applied to the view when I tried it in ST9.
Greg
Hi @SeanCresswell
Just to let you know you've helped solve a similar problem I've been having a year on!
