ST9 Graphic Problem
I was using ST8 and it was working fine but now with ST9, my graphic card is no longer working..
I have lower the View setting to (Software Driven) it helps but it's lagging more.
Can I lower other settings ?
4 REPLIES 4
Re: ST9 Graphic Problem
Community Manager
More than likely a graphics driver issue. Contact GTAC/partner to find the right driver for your machine.
Dan Staples
I get that every once in a while when moving dimensions but have  been unable to repete it enough to bug report it.
I had this problem with ST8 after working with many parts.
The problem is that your RAM will run full, a SE reboot is required.
But try to update your graphic driver and clean your %temp% folder.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Yes it's definitely a graphic card issue but I have legacy card so no more driver uptade. I will have to update the graphic card or change the machine.
