ST9 - Hatch in Assembly Drawings
I'm having a problem with hatching between components. The hatch always 'leaks out' into the screw like this when threads are involved. Has anyone had, and even better, solved this problem?
I've tried processing intersections form the Advanced tab in drawing view Properties. The threads by themselves are displayed good.
1 REPLY 1
Re: ST9 - Hatch in Assembly Drawings
Hi: Jason has given some tips on making a hatch successful in his last post in this thread: http://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Drawing-View-Boundary-Creation/m-p/3... ~Tushar
