ST9: Jog 45°
I try to make a jog but in 45°, not 90°.
Any idea how to do this?
rkuKH7j
A contour flange is to complex here. The base part hasn't 90° angles.
Solid Edge ST10 & AutoCAD 2019 user
Re: ST9: Jog 45°
you could do it like this:
Yasser
Re: ST9: Jog 45°
If you moved it to synchronous, you could rotate the centre face back 45degrees.
Alternatively you could create the jog with a lofted flange, though you'd have to be careful with your sketches so as to not to create a twist in the sheet.
Re: ST9: Jog 45°
Siemens Legend Siemens Legend
Siemens Legend
Joris,
if you want to stay in the Ordered environment:
Isn't a 'Jog' by nature 90°?
So by placing two 'bends' a' 135° this could be achieved?
Good luck /Ulf
Siemens EMEA GTAC Support
Re: ST9: Jog 45°
There are some ways to do this, but synch is much simpler.
Here is a video about steps:
BR,
Imics
Re: ST9: Jog 45°
Re: ST9: Jog 45°
Tight deadline, so sorry, not all read.
In attachment my work around. "Rughaak_Links.psm" is the base part.
Don't like synch because we use a lot 'insert part copy' and the links has to stay alive.
Will look at all you answers in detail this evening.
Re: ST9: Jog 45°
Thanks, I watched both video's.
So in short: the thing I was looking for doesn't exists. Man Tongue
