ST9 Meshing Issues
Hello Everyone,
I'm having some difficulty meshing out a part for buckling analysis.  I've extracted a surface from my thin walled part and have simplified the geometry somewhat to eliminate some small sections.
The problem that I'm having is that I keep getting the following error and cannot find any way to locate the culprit element.
Is there any way ot locate a specific element or failed elements in Solid Edge?
Thanks!
Re: ST9 Meshing Issues
I have a tipp. Pls, try to toggle "Maximize quad elements" option off (Mesh option -> Surface mesh tab).
BR,
Imics
Siemens Legend Siemens Legend
Siemens Legend
Aday,
for a Solid Mesh you have a 'Mesh quality' check of elements.
Deselect 'Modify study/generate only surface results', and then 'RMB/show poor quality' on the Mesh in Pathfinder. This will highlight the bad elements.
But as far as I understand not for a surface mesh.
Good luck /Ulf
Siemens EMEA GTAC Support
Thanks for the suggestion!  Turning off the "maximize quad elements" helped significantly.  I also had to mesh it with a very fine mesh, but that didn't get me there without turning off the max quad element option.
Thanks again!
Cool! Smiley Wink
BR,
Imics
