ST9 Part - Shading on Selecton
PLM World Member Pioneer PLM World Member Pioneer
Does ST9 behavior for shading on selection of a region turn off after the first selection?
It seems to (if turned on) highlight the faces of parts but not regions after the first time.
ST9
Win10 / 64
32GB
Quadro 600
Re: ST9 Part - Shading on Selecton
After the first selection, region or single, the Ctrl key need not be used for subsequent selections. Can you check this ?
Re: ST9 Part - Shading on Selection
It does add a region if you hold Ctrl. It looks like it was a graphics card
hiccup, They select correctly now after a re-boot.
Steven Zimnoch, P.E.
Mechanical Engineering Manager
The Lanly Company
216-731-1115
szimnoch@lanly.com
