Re: ST9 - Problems with Design Manager
I have made some testing and on 2 machines with same specs, one is running fine but on the other the design manager is slow. Any clue why is that?. When I speak about slow is traversing and assembly when you make changes, I mean the iterating process of reading links, etc, that design manager do is slower in relation with the other machine and Revision Manager. Both computers are accesing files in a network server
Hi @RamonRuiz
and have You chekced the connection quality to that server?
Together with the file access rights of the users.
Can You see the same behaviour when doing the test locally?
 Antivirus Software maybe with exclusions on one machine while ot on the other?
Wolfgang
