ST9 - Show References parts as transparent
This option doesn't seem to work. Am I the only one who has this problem? Refrence parts should always be transparent.
ST9
Conveyor and industrial equipment designer.
Giving SE a chance.
Re: ST9 - Show References parts as transparent
Esteemed Contributor
No, works just fine.  The setting you are changing is global setting that affects NEW views placed.  It will not change existing views.  To change existing views, right mouse click on the view, select Properties, click on the Model Options tab, then change the "Show reference parts as transparent" setting as desired.  Your view will most likely go out of date so just update the view to see it in the new state.
Production: ST9 MP10
Testing: ST10 MP3
Thanks! I had to go change the setting in the draft template I was using for it to work.
But you gave me the hint.
Regards.
ST9
Giving SE a chance.
You only need to add it to the template if you always want this as the default setting.  Otherwise if it is for the occasional "one-off" drawing view, change it through the view properties.
Testing: ST10 MP3
Exactly!Thanks
ST9
Giving SE a chance.
