ST9 performance down after Windows 10 Update
Has any body found a performance degrade in ST9 after a Windows 10 update.
7 REPLIES 7
Re: ST9 performance down after Windows 10 Update
Which Windows 10 update?  We are on build 10586.589 and not seeing any issues.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
@Trevor,
Well yes we have just been talking about this. I had initially attributed it to increased user traffic on our wing of the network, but perhaps there is something more to it.
@KennyG = my windows version is 1607 [build: 14393.693]
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
Actually was looking at something old.  My current build is 10586.753.
@SeanCresswell We never took the June refresh that it would put us on version 1607.  It's on our "to do" list to push that upgrade though...
Ah.......I wonder if Development has this 1607 version to check SE against?...Win10 might need a bit more flushing through, if not.
1607 [build: 14393.321]  No issues of note here.
Bruce Shand
There is a problem.
The part that can be talked about first is a link update error if you make the part library window visible.
This issue would have been reported.
And .. error occurs according to user setting value.
Windows10 1607 is a problem.
Also, once you upgrade, you can not go back.
What is the problem and the setting?
Bruce Shand
