ST9 standard Parts not working
Dear all,
I am trying to set up Standard parts for Solidedge ST9 in my machine,
System configuration:
Wndows 10 Pro, 16 GB Ram, I7 Processor.
Adding parts in the Standard Parts Administrator was sucessful.
when adding fastner in the assembly,
i select the edge of the hole and the face, but the fastner dialog box doesnt appear.
it appears as small dialog box with - and x (circled in the screen shot).
Any suggestions please.
thank you for your help.
Kind regards
Jerry
Re: ST9 standard Parts not working
I can't see anything in your photo except part of a redline in the lower left.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
My first suggestion is to check your MP version (newest is MP4). Install it in case you haven't done it yet, then empty your temp folder:
- Type in %temp% to Windows Explorer.
- Select all (CTRL+A), delete all (SHIFT+DEL).
- Few instances couldn't be deleted, so just click Ignore on them.
- Try to place fasteners again.
This may not be the solution, but it's recommended to check these in case of unusual software behaviours.
Attila
I suggest running regedit.exe from command prompt and looking for following registry key: HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version 109\General\Position\AssemblyComponentSelection & rename it.
Try to run your workflow once again.
BR,
Imics
Thank you all.
Renaming the registry and clearing the temp worked fine.
