STACK BALLOONING
Is there a way to create stacked balloons for item numbers in a draft similar to SolidWorks?
(ie. select the first part, place the balloon, then as you keep selecting parts the part number ballons stack up on the first balloon.)
Re: STACK BALLOONING
Esteemed Contributor
No auto stacking but you can drag a balloon over another and they will stack.
Bruce Shand
That will work. Thank you.
Community Manager
If you use the Fastener Stack technology in Solid Edge (places bolt, nut and top/bottom washers all in one) this will auto-stack the balloons in Draft.
Dan Staples
@dcstaples, That's true if you like the standard parts library. I don't. It would be nice if, in the fastener system, you could specify your own parts which you have set up separately from the standard parts library.
Bruce Shand
