STEP 242, how to save PMI
A supplier of mine (vendor of a different cad system) asked me if SE can export/import in STEP 242 format.
I googled a few minutes to understand what 242 stands for: it seems that the nice thing of this standard is that it allows the transmission of PMI data, other than geometries as usual.
I did a little test:
created a par with PMIs
exported to STEP 242
imported the STEP file in SE.
Unluckily, no PMI data are shown in the imported step file. Do I miss something? I have a ST9 Foundation license.
PMI are imported as expected if I do the same test but using JT format instead of STEP 242.
____________________________
http://www.stimarchetti.it
Design of automation
Re: STEP 242, how to save PMI
Alessandro,
unfortunately SE does not currently support PMI in step-files.
You should add yourself to ER#1557764, via your support.
Good luck,
/Ulf
Siemens EMEA GTAC Support
