STEP FILE ASSEMBLY ISSUES
Builder
Builder
I have imported a STEP file assembly that was made in Creo Elements. My issue is that the sub assemblies are "stuck" together. There are no constraints holding any of the parts in place, but when I select to move on epart in a subassembly, the whole subassembly moves. What is the solution? Is there a menu option that I misssing?
Thank you
1 REPLY 1
Re: STEP FILE ASSEMBLY ISSUES
When you select the individual part that you want to move, look at this setting in your QuickBar:  This will toggle moving the part vs. moving the subassembly.
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
