STEP Files Translation Problems
I am trying to translate a STEP file into an .asm and get the following error message:
Any ideas? I've have been able to translate STEP files successfully in the recent past.
Peter
Re: STEP Files Translation Problems
Make sure that the location the STEP file you are trying to open is writeable and has suficient space.  The translator needs to write files to that location and if it can't, you get that response.
http://Grundey.blogspot.com
Thanks, Ken - I checked those things but the location is writable and has plenty of space.
I think you can also override the default output folder so you might check that if you haven't.  Aside from that, I have no idea.
Ken,
I think I've got this one solved. The files I was trying to translate were downloaded from the Internet to my Downloads folder. When checking the properties on the Downloads folder I noticed the Read-only (Only applies to to files in folder) box was filled in, not checked. I cleared the box, saved the file to my desktop and was able to translate the files successfully. Thanks for your assistance.
Peter
Glad you got it worked out!
Ken,
I downloaded some more files today and ran into the same issue. Interestingly, I was able to translate the file as a part but got the same error message if I tried to translate it as an assembly.
Peter
Yea, I don't believe Part has to write out files during the translation.
