STEP file output
I am trying to output a STEP file with only certain parts from within a Sub-assembly. I used to be able to check the radio button that said "Export Displayed Only". I have several parts visible, and activated, and go through the steps for the translation. When I open the STEP file, I do not get all of the parts. Does anyone else have this problem?
Peter
Re: STEP file output
Answered my own question. I had been trying to save the STEP file from the sub-assembly, which did not work. When I went back to the Top Level Assembly and saved it with the "Export Displayed Only" checked, then it worked as designed....
Although you answered your own question, you did teach me something I did not know. We often get requests for STEP files and only want to send them the shell of our products. Now I know I can uncheck them in the feature tree and save as displayed. Thanks!
Owner: Scott Lester Drafting & Design
Designer: Rotork Instuments
