Save As pdf
Not applicable
Does Solid Edge 2D support the Save As pdf command I do not have a Save As pdf in the Save As menu? (SE ST4)
I talked to one of the office supply stores they can print the larger drawing but they want them in pdf.
Dan
Re: Save As pdf
Not applicable
Found an answer i the forums the 2D does not support the save as pdf.
Maybe it will someday.
Dan
Re: Save As pdf
Not applicable
Download "CutePDF". It acts as a printer driver so you just choose it as your printer and then it asks you for a file name to save as a PDF file. It works very well.
Re: Save As pdf
Not applicable
Does CutePDF read the "paper size" from Solid Edge when you print to cutePDF
Can I print a D sheet and D size pdf file (so I can take it to print shop and have them print a D size sheet.)
Dan
Re: Save As pdf
I do not believe it does. Always defaults to 8.5x11 portrait or landscape.
http://Grundey.blogspot.com
Re: Save As pdf
Not applicable
Dan
When you select CutePDF as your printer you need to set up the options just like any other printer, only it prints to a file instead of a physical printer.
Ed
