Save as 3d PDF
I have a bit of my macro which saves a pdf, but now i want to export the asm or par as 3d pdf, can you guys point me in the right direction and/or help me a bit?
This is the code to save my draft as pdf, which isn't neccesary anymore, because we use an add-in which exports a pdf every time i save the document.
And i know i have to change some more things, because it was used to be for the draft environment.
Private Sub Button_SaveAsPDF_Click(sender As Object, e As EventArgs) Handles Button_SaveAsPDF.Click
        Form1.SEDraftDocument = Main.seApp.ActiveDocument
        'Het pad specificeren waar het bestand moet worden opgeslagen
        Dim SESaveAsPDFPath As String
        SESaveAsPDFPath = TextBox_OpslaanIn.Text & "\" & TextBox_Bestandsnaam.Text & ".pdf"
        'Extra check zodra bestandsnaam wordt gewijzigd --> infobox
        If TextBox_Bestandsnaam.Modified = True Then
            Select Case MsgBox("Weet je zeker dat je de bestandsnaam wilt wijzigen?", MsgBoxStyle.YesNo, Title:="Bestandsnaam gewijzigd")
                Case MsgBoxResult.Yes
                    Form1.SEDraftDocument.SaveAs(SESaveAsPDFPath)
                    Me.Close()
                Case MsgBoxResult.No
                    Main.SEDocumentPropertySets = SEModelDocument.Properties
                    'Vul bij bestandsnaam de document number van het gelinkte model + de bestandsnaam zonder extensie
                    For i As Integer = 1 To Main.SEDocumentPropertySets.Count
                        Main.SEDocumentProperties = Main.SEDocumentPropertySets.Item(i)
                        For j As Integer = 1 To Main.SEDocumentProperties.Count
                            Main.SEDocumentProperty = Main.SEDocumentProperties.Item(j)
                            If Main.SEDocumentProperty.Name = "Document Number" Then
                                TextBox_Bestandsnaam.Text = Main.SEDocumentProperty.Value & " " & SEDocumentName(0)
                            End If
                        Next
                    Next
            End Select
        Else
            Me.Close()
            SESheetWindow.Update()
        End If
        'Check of de draft al is opgeslagen
        If Form1.SEDraftDocument.Path = "" Then
            Select Case MsgBox("Het draft document is nog niet opgeslagen. Wilt u deze nu opslaan?", MsgBoxStyle.YesNo, Title:="Draft niet opgeslagen")
                    Form_SaveAs.Show()
                    Me.Close()
            End Select
        End If
    End Sub
Thanks folks!
4 REPLIES 4
Betreff: Save as 3d PDF
Hi @JuRi
try to modify the save line for the PDF with ...(SEPDFPath, ,True)
This additional parameter (which IMHO is not described in any documentation) gives a 3D PDF as output format, rather than a 2D PDF
Wolfgang
This seems to return just the normal pdf for me. I've put some thing of the code underneath. my SESaveAsPDFPath returns ............................\filename.pdf
    Public SEPartDocument As SolidEdgePart.PartDocument
    SEPartDocument = Main.seApp.ActiveDocument
    Dim SEPartDocumentpath() As String
SEPartDocument.SaveAs(SESaveAsPDFPath, True)
Hi @JuRi
double commas!
SEPartDocument.SaveAs(SESaveAsPDFPath, ,True)
Wolfgang
Thanks! This did the trick.
