Save as PDF with only selected lines
I am trying to export my drawings to be used with a plotter/cutter, which means I need to only export the outlines of the drawings. (The drawings are garment cutting patterns, meaning they have a base geometry which is NOT cut, and outlines which include seam allowances and notches which ARE cut.)
I need to export only the outlines, with no construction geometry or dimensions. Is there a way to set my printing preferences/drawing view to only display/export certain line types, and not display dimensions?
Re: Save as PDF with only selected lines
Try organizing your geometry on layers. Put dimensions on one layer, and different types of geometry on different layers. Show/Hide the layers as needed before saving as PDF.
Rick B.
