Save as Translated
In the previous version I was able to save as translated DWG ... I do not see that option after updating - what gives?
Is there a patch to be able to save in this method?
Re: Save as Translated
Hi there,
Is working fine for me.
What version "STx" have you updated to? ...and what build??
Also...the DWG exporter only works for 2D draft files. [in case your trying to export a 3D model]
Testing: Solid Edge 2019
