Saving Part as an STL
N/A
I tried to save a part as an STL file in order to make it on a 3D printer. A log file and a certificate, but no STL file. Any thoughts or suggestions?
Re: Saving Part as an STL
Hi there,
Just a hunch, but, might your model be open surface data?
Also, have you read the contents of the log file?...it may indicate the issue in there.
Streetscape Ltd
sean@streetscape.co.nz
Sent from my Samsung Galaxy S4 using Tapatalk 2.
Solid Edge ST10 [MP7] Classic [x2 seats]
Make sure you turn off the Windows Explorer option "Hide file extensions for known file types". The file listed as the "certificate" is the STL file.
Production: ST10 MP6
Testing: SE 2019
N/A
Solved the problem.....operator malfunction.
Haha, yes that is a common issue, even for some long time users, such as myself. :rolleyes:
BTW....if you haven't discovered it yet, there is a NEW open forum for Solid Edge now.
Highly recommended signing up.... http://community.plm.automation.siemens.com/t5/Solid-Edge/ct-p/solid-edge
