Saving Sheet As DXF or DWG
Not applicable
Is there any way to save one sheet of a multi-sheet drawing as a dxf or dwg? I would
like to send one sheet to my vendor to quote on the one piece which is on that sheet.
Ed
Re: Saving Sheet As DXF or DWG
Not applicable
Ed,
When you select .DXF as the file type for save, the 'Options' button on the
Save As dialog will be enabled. Click on the Options button. This will start
a Wizard that allows you to customize the translation. Click Next at the
bottom of the dialog. On this page you will see 'Sheet Options'. Click the
option for 'Active Sheet Only'. Click Finish. You will be prompted for a
file name for your cistomized configuration file. Give it a unique filename.
Now when you save the DXF file whatever sheet is active at the time you save
will be written to the DXF file.
Rick B.
Not applicable
Thank you Rick. It works great.
Ed
"Ricky Black" wrote:
>Ed,
>Regards,
>Rick B.
