Saving assembly as SAT to import into revit
We have a customer who wants to put our machines into Revit for their building layout.  When I export my assembly into an SAT and then reimport it back into a part file to check it, I get the standard message about multiple faces.  I've tried several tricks but the end result is that I want a single part without all of the faces.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Re: Saving assembly as SAT to import into revit
Have you tried saving out to an IFC file?
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Builder
Builder
Kyle Kens right try the IFC (Industry foundation classes) format new in ST9.  I'd be interested to see how you go as I may have a similar requirement.
From Revit after import you may have to create it as a family.
Cheers
Phil
ST9
WIN 7Pro 64bit
DELL T5810 3.7-4Ghz 32Gb ECC
