Scale assembly
I need to scale my assembly. I am trying to do so but i am getting my assembly as single part (.par) and my
components of that assembly also do not get scaled.
Kindly help
Thanks and Regards,
Ashish Sarode
Application Engineer
Re: Scale assembly
There is not a great way to do it but if you just want to scale something this is a way.
- Open an part.
- Select "Part copy".
- Select model.
- In the new window you have the option to scale.
I use this when i get STEP files in the wrong scale.
Sander
The Netherlands
Re: Scale assembly
Thanks for the reply,
I know about scaling parts, what I want to know how to scale an assembly directly, without scaling the components individually.
Re: Scale assembly
You can select an assembly and then you can scale the entire assembly within that part.
Sander
The Netherlands
Re: Scale assembly
I tried that but the whole assembly becomes a single part (.par). I want assembly as a scaled assembly.
Re: Scale assembly
Thats what i tried to say. What i know, thats not possible.
Sander
The Netherlands
Re: Scale assembly
What you could try after you got the entire assembly inside the part. Make a STEP file and generate that step file in an assembly.
You would have a really stupid model, but i don't know  what you want with the model after the scale.
Sander
The Netherlands
Re: Scale assembly
The best I think you can do is create a scaled multi-body part when insert part copying the assembly. Then do a multi-body publish as an assembly and break the link.
Bruce Shand
Re: Scale assembly
MLombard
Retired
Yeah, we don't have a good way right now to scale an assembly directly. But did you know there is a scale factor within the IGES header (and I think the STEP header as well) so that you can text edit the IGES file to scale the entire import? This could save you a lot of headache wen you import an assembly scaled in correctly.
Re: Scale assembly
@MLombard, what do you think of the method I mentioned?
Bruce Shand
