Scale solid
Is there a way to select a solid and simply scale it? It's incredible how difficult is to find the way to scale a simply 3D part without doing Insert-Copy.
Marc.
Re: Scale solid
Perhaps if you could explain what you are trying to do the community might be able to suggest another approach.
Cheers
Mark
Re: Scale solid
I'm trying to scale a part. So I created a part and I want to scale it without insert it in an assembly. There is a scale option in wireframe operations but I can't find how to scale a "solid" part without using insert part or insert the part in an assembly.
Is there any "scale" icon to scale a 3D file or I need to open it into another part or assembly to scale it?
Marc.
Re: Scale solid
Like "Scale body" in NX
Re: Scale solid
There is no direct way in part environment "only" what you know (Insert part-copy)...
I agree with you, it should be useful... Smiley Wink
BR,
Imics
Re: Scale solid
Honored Contributor
Honored Contributor
if you found any way to get this done your doing well. I would like to be able to scale sheet metal box's!
Re: Scale solid
So,
There in no way to scale a solid in Solid Edge in its own file? You need to insert it in another file to scale it?!? Smiley Frustrated
I expect a simply scale body option in ST8 Smiley Wink
Re: Scale solid
Yes, this is something we've been waiting for years...
