Seec message.
Hi Guys.
Why am I getting this message?
I am only doing one thing at a time.
Kind regards
7 REPLIES 7
Re: Seec message.
you need to delete your SEECTransLog.xml
found in your SEEC Cache location
Matt Johnson
Solid Edge Certified Professional
Solid Edge 2019 (SEEC) - Production
NX12 (Tc Integration)
Teamcenter 10.1.7
Re: Seec message.
Hi Matt.
Ok Thanks.
But why am I getting this error?
It seems for no reason at all.
Darren
Re: Seec message.
@Dazzie
I don't know the actual root cause.  seems like at times transactions fail or hang in some way.  nothing you did didn't do that caused it.
Matt Johnson
Teamcenter 10.1.7
Re: Seec message.
Thanks Matt.
Just another pointless thing Teamcenter does.
Darren.
Re: Seec message.
As users of Insight we also get hung up, lost transactions, cache mismatches on a random basis. I suspect network hiccups as a cause but that's just a guess.
Bruce Shand
Re: Seec message.
@Dazzie perhaps @Johnson_BigMatt's post was the proper solution?
Bruce Shand
Re: Seec message.
OK, you put your reply to Matt as a solution. His reply should be marked. And I think you can unmark mine.
Not to be a stickler and it's not a big deal but you might as well learn.
Bruce Shand
