Select Tools - Feature question
just wondering if you know how to add Select Tools feature to the customized theme or how to find this command from different location ?
Select Tools.pngSelect Tools
Thank you,
Arek
Re: Select Tools - Feature question
I'm not sure exactly what you're after but here's how to get back disappeared edgebar items using the view tab. As for it staying visible with your theme if you exit SE the appearance of the edgebar is saved with your theme. At least that's the way it seems to me.
(view in My Videos)
Thank you Bruce. That exactly I was after.
Arek
@arekkul
@bshand
Speaking of Select tools, we've upgraded to ST10. The thing that I am used to seeing is when you do a query the items glow when you place that name or part number into the query field.  Now it does not.  See attached for an explanation.
In the vid you see a list of parts with name and numbers, let's use 200-0065 ergo.
When I select using the shift+right click, all the items glow.
When I goto the select tools and preform a search of the same number, nogo, no glow.
Any ideas?
https://www.youtube.com/watch?v=53oN3E-EwwE
Thank you for your input.
What is the query field set to search on? Right click on the query field and it will show a list of many properties to choose from.
@bshand
It appears to be.
@Lex-luthorwrote:
found it!
http://www.designfusion.com/designfusion_blog/how-to-search-the-assembly-pathfinder-for-a-named-comp...
Weird that there was no help in the "help section"
Not really that weird. Help is generally pretty poor IMO.
