Select - hidden under the tree
just a quick question.
I have attached the video with the issue visualized.
All about the Select Window which is hidden under the tree.
Is there a method to set a fixed location ?
thank you,
Arek
(view in My Videos)
Re: Select - hidden under the tree
Odd,   I uggest filing an IR on this... the video is sufficient to show your issue...
BUT...  try toggeling the PF from tranparent to docked...  i'm hoping that the docked PF will force teh select box to be visable and thus selectable.
You can quickly toggle the PF state by holding CTRL and double clicking the PF header
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Matt Johnson
Teamcenter 10.1.7
