Selecting objects
Not applicable
When I select an object by a 2 point rectangular frame, all the items in the drawing
show selected and not the item I want. What setting corrects this?
Re: Selecting objects
Not applicable
>drawing
Dan,
In the upper left corner of the ribbon bar there is a drop-down menu that selects
the type of "select" that is active. It is probably set to "Outside" or "Outside
and Overlapping". You want to set it to "Inside".
Ed
