Separating holes from a group of holes from "Recognize Holes"
I have an imported part and used the recognize holes commandin Syncrhonous.  I need to separate some of the holes so I can change their size and also so they are not part of one "hole command".  In "hole 7", I need to separate holes 21, 22, 23, 24 & 25 out of that group.  I need to make them larger and also don't want PEM studs to pattern into those holes.  How can I separate them into their own group?
Thanks!
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Re: Separating holes from a group of holes from "Recognize Holes"
Select all the holes you want separated from the original group and placed in a new group and choose "Separate" on the shortcut menu.
http://Grundey.blogspot.com
Hi Ken,
I figured I must be overlooking something.  I realize now I had the model set to ordered.  Once I switch to Synchronous, the shortcut menu appeared.  Thanks for the help.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
