Sheet Metal - Cross Brake
Have imagined this or did there used to be a cross brake funtion in sheet metal in st8 or 9 that isnt now in st10?
3 REPLIES 3
Re: Sheet Metal - Cross Brake
It's only available in the Ordered environment. It's located in the drop down under the Dimple command.
thanks, i rarely use ordered.
"thanks, i rarely use ordered."
Somebody notify the Marketing department, STAT!
This sounds like a case study worth publishing.
____________________________________
--Scott Wertel, P.E.
