Sheet Metal Weldings
Hi all,
Is there a way to model a weld in asheet metal file (psm) and not as a new weldment?
Re: Sheet Metal Weldings
Esteemed Contributor
Hi there,
Not really....I mean you could obviously model the weld material, as a multi body file, but technically not a "weld" in the software's methodology, so doesn't carry through for detailing in draft.
Solid Edge ST10 [MP3] Classic [x2 seats]
Honored Contributor
Honored Contributor
I make tons of sheet metal parts and assemblies. I have never used the "weldment" designation. As far as I can tell, that designation allows the addition of weld call outs and no other advantages.
@12GAGE,
I think you can get a little more than just the callout....you can also get mass properties from them....which in turn, allows a QS to calculate the wire/rods/gas/time, relative to them, assuming there is a lot of weld material to justify it. Unless structural approval from drawings are required, I see it as a wasted effort for smaller welded parts/assemblies.
Just my $0.02NZ worth.  Robot Embarassed
