Sheet metal Integral Tab
Hello Community,
Please can you advise how I can create an integrated tab, see green edge that I have tried to extend out using the flange command however it did not work. Please advise and see enlcosed.
Thank you in advance
Re: Sheet metal Integral Tab
Hi there @TeslaCannon,
I suspect it's because of the shear that would occur at the "Down. vs. Up" tabs......try creating a small side relief there. [ie; a slightly narrower tab]
