Sheet metal bend lines in ST10
It has been brought to my attention that the VERITCAL callouts created by the bendtable command are not lining up like they did in ST3, ST5 and ST8. I have gone all through the setting and i can not find a setting that handles this. In this image below, you can see how they are showing now. I adjusted the VERITCAL callout to the left to show you how they were prior to ST10. Has anyone else seen this? CALLOUT.JPG
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
3 REPLIES 3
Betreff: Sheet metal bend lines in ST10
Hi @ngardner
I can not see a big difference from ST10 and prior, but I have not found any compare date at the moment.
What could be is, that for vertical callouts they are left orientated to the middle of the bend.
The horicontal seems to be centered.
Wolfgang
That was my first thought but i saw no change when switching back and forth. Your image looks like its aligned better than mine????
Nathan M. Gardner
Hi @ngardner
I also repeated the test with a longer callout (bend number - bend angle  and bend direction).
I also can see that my horicontal callouts are centered while the vertical are shifted to the right (upper) side
Wolfgang
