Sheet metal slot radius
Builder
Builder
How do I modify the raduis of a slot created in a sheet metal part ? I cannot find the option to change the radius
Solid Edge ST8
Re: Sheet metal slot radius
Assuming it is Synchronous,
after selecting the slot feature from the PathFinder, click the word in the callout called "Slot 1" that appears on the slot feature in the graphics window.
https://drive.google.com/open?id=0BzJCobZYCLMjd3BmY3ZYQXAyU1k
https://drive.google.com/open?id=0BzJCobZYCLMjZ2t3Z0ltSUxVSFk
~Tushar
Builder
Builder
Hello Tushar, please can you post a few screens on how to do this ? I am unsure what you are describing
Hi @agoodwin
I started my previous reply with posting some images, but it is so frustrating to see the images not appearing in this forum after several attempts. It simply refuses and does nothing.
I have updated the original reply with links to images.
Please check them.
~Tushar
Builder
Builder
Thank you very much Tushar, I have seen your images on the links, the problem is I have created the part with the slot in ordered not synchronous so the callout does not appear, how do I modify the slot radius in the ordered environment ?
In ordered, select the slot feature in the PathFinder and select the 'Edit Definition' from the floating bar.
https://drive.google.com/open?id=0BzJCobZYCLMjU29LdnVrZ0RLT3M
Then from the Command Bar, select the first button 'Slot Options' to edit the width.
https://drive.google.com/open?id=0BzJCobZYCLMjblRiWlg5TjNOaEE
Builder
Builder
Perfect thank you, this has worked a treat Smiley Happy Thanks for your prompt help
Honored Contributor
Honored Contributor
So this procedure is why I avoided using the slot tool and just sketch the slot out. When learning software stuff like this makes it frustrating.
I may start using the that feature in the future to easier hole/slot alignment
Nice thread
