Sheetmetal Midplane Surface Export
Is it possible to export just the sheetmetal midplane surface to a STEP file (or other file type)? I keep getting a "this model contains no bodies" message when I select the  “export display only." I'd like to use the midplane surface for an FEA analysis outside Solid Edge.
David McMahon
Solid Edge 2019
HP Z2 Mini, Windows 10
Re: Sheetmetal Midplane Surface Export
Use "export sheets (construction)" option.
BR,
Imics
Imics,
Awesome, that worked!
David McMahon
Solid Edge 2019
Interesting. What is a "sheet body"? Is "sheet" referring to sheet metal?
ST10 MP7 - Insight - Win10 - K4200
My understanding has always been that "sheets" refers to surface geometry as opposed to solid geometry.  "Sheet metal" is just an unfortunate misnomer in this context.
