Sheetmetal Midplane Surface Export
Is it possible to export just the sheetmetal midplane surface to a STEP file (or other file type)? I keep getting a "this model contains no bodies" message when I select the  “export display only." I'd like to use the midplane surface for an FEA analysis outside Solid Edge.
David McMahon
Solid Edge ST10, MP3
HP Z2 Mini, Windows 10
Re: Sheetmetal Midplane Surface Export
Use "export sheets (construction)" option.
BR,
Imics
Imics,
Awesome, that worked!
David McMahon
Esteemed Contributor
Interesting. What is a "sheet body"? Is "sheet" referring to sheet metal?
Bruce Shand
My understanding has always been that "sheets" refers to surface geometry as opposed to solid geometry.  "Sheet metal" is just an unfortunate misnomer in this context.
