Shortcut key strokes not working
Builder
Builder
When in a draft drawing, the shortcut key strokes (such as %DG for a degree symbol) does not work. When typing notes I have to use the icon menus, which is slowly becoming very annoying. Any ideas on why this may be.
For a degrees symbol try using alt0176.
Re: For a degrees symbol try using alt0176.
Builder
Builder
Nope, this doesn't work either.
Esteemed Contributor
How are you creating you notes... Callout or Text Box?
What version of SE?
ALT+0176 works for both but you must use your number pad while holding down the ALT key. The row of numbers at the top do not work.
The Callout feature only takes the %DG shortcut. In later versions of SE (maybe ST4 up) the Text Box command has a "Select Symbols" option on the command bar to insert things like the ° symbol.
Production: ST10 MP3
Testing: SE 2019
Builder
Builder
I am using Text Box in ST6....
And thank you, the extra info about the number pad did the trick. I was using the top row numbers.
Then you should also have the Select Symbols option on your Text Box command bar that will allow you to select them graphically as well (hexagon with "ST" in the middle... expand Symbols/Dimensioning nodes).
Testing: SE 2019
